1 - 20 of 25 Posts
I've got an SV650 2007 which I've been using as a daily rider. But I struck some ice (yes, southern hemisphere!) exiting a slow roundabout and the rear just went out from me. A scratch on my leg but not happy to have my bike down. The mechanic who's looking over fixing what broke (clutch lever, gear shifter, handlebar twist) is getting a price on a factory new handlebar but in his words: 'it might be drug money'.
So looking for suggestions for a 3rd party handlebar. The Renthal black looks nice but it would be good to know that it fits (i.e. side to side movement isn't constrained by cables).
Are these naked bars? If not creased or seriously tweaked they can be bent back to position.
A 3ft section of pipe over the bar end will give plenty of leverage.
Yep. Naked. I don't have any sort of workshop and as the mechanic is doing it, I'm thinking black bars would be cool anyway. His call really about whether they can be 'tweaked' back into place.
If you go aftermarket, I think you will need to modify the throttle and the turn signal/high beam pods. There is a little nub inside that line up with holes on the stock one bar to prevent twisting and it spinning on the bar. Am I correct in assuming that yours has that as well? Not a big deal, very easy mod it seems, just something to be aware of.
I don't know if they're available over there, but Bikemaster Superbike bars are very similar to the originals. Just a touch lower with a bit less sweep, I find them more comfortable. They're cheap, easily shortened and can be drilled to accommodate the above-mentioned nub.
I've purchased and installed numerous BikeMaster bars over the years.
I'm fairly certain these are BikeMaster Superbike bars -
Different bend than stock, but more comfortable IMO.
'00 SV650YE03, '08 SV650AK8
I'd just heat the old ones up and bend them back as close to the correct bend you can get. Then I'd order these that I bought from China. They are fatbars and are a perfect fit. Very comfy.
I bought them from aliexpress.com. All in they were around $40 US. Be forewarned, they take FOREVER to get here from China but they do eventually show up.
US $13.49 20% OFF|Motorcycle 1 1/8 and US $12.11 22% OFF|Universal RIZOMA 6061 Aluminum Alloy Sand Blasting Technology Finished Fat Bar Motorcycle Handlebar 72CM 1 1/8'' 28mm guidon de|Handlebar| - AliExpress.
Just curious, did you check partzilla for the OEM bars? If you want a different bar, no problem...but if you are just looking for OEM bars, I replaced my OEM with an OEM from Partzilla and it was about 70$ with shipping.
On the subject of handlebars, did anyone ride with one of these?
I like the look of them, but are they comfortable? Do they put a lot of strain on the wrists? How do they change the riding position?
The previous owner of the bike has put a wider bar and I'm having problems filtering through traffic (it's legal here).
@Edit: Now I see that they're similar to the discontinued Suburban Machinery Type2. Anyone has them installed and could post dimensions here? How comfy are they compared to stock?
Hi Marhan. I have Suburban Machinery Type 2s on my 2008 650 Naked in the stock risers with bar end mirrors. The bars were bought originally for my '01 Yamaha FZ1. I used them on that bike, which I traded 2 years ago, from 2003 to 2010 when I switched to second gen FZ1 bars on that bike.
The bars sat in a box for a long time and when I got my '08 SV 650N last October, I decided to try them on it. My last SV was an '07 1000 that I put an LSL bar riser kit on with the OEM bars from my '01 FZ1 on. Hated those bars on the FZ1, but loved them on the SV1000, go figure.
Anyway, I love them on the '08 650, feels about the same as my SV1k with the higher set-up. So, lower than stock on the SV650 Naked, a bit narrower, and leaned forward a couple of inches. I am still mostly upright, just a moderate lean forward, like a sport tourer. To me, still comfortable. YMMV. I don't have dimensions for you, sorry, but I just eyeballed it and went for it. I'll try to take some measurements but don't know if it'll help.
That would be a HUGE help, thank you! Just the basic dimensions like the ones that I posted would help me get the closest match.
Marhan, I tried to measure as best I could with the bars on the bike. After converting from inches to mm, the SM Type 2 bars fall in between the middle and bottom bars in your illustration.
If I'm seeing them right, those bars have a "rise" to them from the clamp area. SM Type 2s are totally flat, 0 rise. I googled SM Type 2 bars, and even though the site is still active, it says these are discontinued. However, there are some pictures of them on a naked SV so you can get a look at them.
I'm glad I held on to mine all this time, but I would try one of those others if I hadn't. They look good on that V-Max.
So they would be more like those bars?
Could you please put SM2 dimensions on this picture? Don't trouble yourself with conversion, I'll convert the values myself.
Too bad they're discontinued. Too be frank they were really pricey but they looked amazing, and I hear a lot of good about them. That's why I'm looking for something close.
Here's my best effort Marhan, hope it helps you. They seem close enough dimension wise, I have no idea of the cost you're looking at. Sadly, it's been so long since I got the SM2S, I can't remember exactly what I paid, I think about $150 USD, but that was back in 2003 or so.
54789
Maybe these pics will help. Taken recently. This is my '08 SV 650 N. It has Ricor Intiminators in the front forks, Ricor rear shock sprung for my weight, Metzeler Sportec M7 RR tires, a Dobeck fuel module from Dale Walker, no snorkel, K&N filter, Galfer Stainless brake lines and HH pads front & rear, the SM-2 bars, imitation Triumph bar end mirrors, smaller turn signals, Puig screen, Suzuki gel seat and tank bra, Yoshimura tail tidy (came on the bike), Delkevic carbon fibre high- mount slip-on, ( full M4 on order), and various parts powdercoated black to match the frame.
I'm having a blast with this one. I knew exactly what I wanted to do to it after I got it. Had been looking for one in this color for about 4-5 years. I REALLY missed and regretted selling my '03 S that I bought new and made into a track/ Mtn. road toy. The '07 SV1k I had for 10 years was also fun, and I'm still keeping my eye out for a nice one.
Anyway, here it is.
54790
54791
54792
54793
Oh yeah, forgot about the Pair Valve, it's gone too, ripped that sucker outa' there! No popping on the overrun, just sweet v-twin bellowing on trailing throttle. I love how this bike sounds when you let off at high revs and let it coast down!!
You are amazing, thank you! There are many alternatives on the web and now I know exactly what to look for, thank you!
And you've got a wonderful bike, I love all the mods. Mine has also seen it's share of modifications:
54794
54795
54796
54797
I like to swap the screens from time to time. I've changed the suspension (YSS springs and shock), changed the exhaust, flashed the ECU, I also have a Suzuki gel seat, K&N filter, new pegs and many more (just yesterday I've installed a brand new led headlight, it's badass!). It's a great machine, I love how it looks and how it rides. It's a bike I plan to keep forever.
LOL. Not amazing, just old. Been doing this stuff a long while. This isn't my only bike, the others are in my sig, so I get to alternate every time I ride. Keeps it from getting stale. That's a sweet ride you have there, those lower bars would be just the ticket. It won't be as low as an "S" with the clip-ons and fairing, about halfway between that and the OEM naked bars. No problems with the stock lines and wires either as long as you keep the stock risers.
Just asking, what country are you located in, guessing somewhere in Europe?
1 - 20 of 25 Posts
