i run the Silverstars and for the $$ I am very pleased.durx said:What have you guys used/liked? I've got one out, need some replacements. Are they hard to change?
Busters in the UKFilthyRich said:i run the Silverstars and for the $$ I am very pleased.durx said:What have you guys used/liked? I've got one out, need some replacements. Are they hard to change?
P.s. where did you order the Bates lights from???
That's because your buddy's single stock lamp has a better beam pattern than the Bates lights. The stock reflector is computer designed to focus the light most effectively for an H4 bulb. This is one of the reasons I switched back from the Bates lights to the stock setup.texinteg said:The problem I am having is that my buddies single stock light with one silverstar bulb is brighter then my dual headlamp setup with silverstar bulbs.
