I'm looking to install a set of Woodcraft clipons on my 06 SV650S and have run into the issue of how to mount the reservoir.
Does the "connector" (59672-17C00) coming out of the master cylinder rotate? This is the hose connector that is inserted into the front reservoir hose on the master cylinder side.
If it does rotate, I'll probably use Woodcraft's handlebar-mounted reservoir mount. Other suggestions for mounting are welcome.
