1 - 7 of 7 Posts
What would be the reasons for not turning over at all? for being 100% dead? not intsrument panel, nada. I thought of the battery. NO. Checked the ground wire. NO. just remembered the fuses will check later. any other suggestions before I call the damn tow truck and pay $75 minimum at the shop? Thanks all.
Did it just stop on you or what?? If your not getting your lights to work or your parking light to work I'm thinking fuse, relay or fuseable link from the postive battey lead..
If it's completely dead, check the main fuse located on the starter relay. It has a green cover and is located behind the RH side cover (black plastic triangular-ish thing under the seat).
thejimdaddy said:
clutch switch, take a wire and jump the circuit
That would be next if your lights and horn work. If not your phucked bigtime.
+++1 also the ignition fuse in the fuse box under the seat
1 - 7 of 7 Posts
