1 - 14 of 14 Posts
Hey All,
I'm looking into getting a rear wheel stand for my SV650. Does anyone have any advice or favorite products?
Thanks,
Bennette
I have a spooled Vortex stand and it's perfectly sufficient. PitBull is the bar but they're a little pricey. I'd get a used one if I went that route.
I have the harbor freight rear stand for the swing arm. No spools needed. For 35$ I have to say, its great.....Can't use spools though, looks like its only swing arm. Pretty solid too, just used it a few days ago to do a chain clean/lube.
The HF stand is definitely cheaper and, as Dominator noted, can't utilize spools which simply make placement of the stand easier/consistent. I had a general swingarm stand from HF and it worked on bikes w/o spools but SVs have them... may as well use them.
On my gen. 3 I have tried stand without spools and with spools: the latter is definitely easier to set, raise, release.
I use a sturdy ConStands, which sells for 50 euros.
54172
BTW larger spools also serve as rear swingarm sliders if you happen to lowside on the left side (I know, I tested them).
  • Like
Reactions: thedrewski86
baller? pittbull
good? vortex
medium? trex
broke? ebay generic chineseum
$0.98 and a death wish? harbor freight
no matter which you get, get spools. they cost like... dollars. and infinitely easier and safer than paddle stands
I have one. It works fine with spools. A bit flimsy though.
To simply service the bike, I’d be okay with the HF. For race duty or to ever sit on the bike while on stands, it’s basically PitBull and Woodcraft and few others. I have some weathered WC and PB stands that are as sturdy as the day I bought them after tons of use.
Not mentioned, but the Woodcraft is a really good stand as well. With that said, get a used Pitbull and it will outlast your bike.
Sent from my SM-T580 using Tapatalk
Read Only
I picked one up at Harbor freight if you happen to have them near by. 1500lb weight capacity it was maybe 50.00 on sale.
Discussion Starter #14
Wanted to say thanks to everyone for responding to this thread!
I ended up buying a Trackside Rear Paddock Stand off of Revzilla for about $70 and a set of Shogun Swingarm Spools. All was super easy to use.
Here's a pic of the bike up on the stand with the spools.
http://instagr.am/p/CC1O83EnNb_/
1 - 14 of 14 Posts
