Now for the fun part here are some pics I took during the install.
I propped up the bike with straps from my ceiling then took off the seat and side trim. In this pic you can see the top shock bolt.
Take out the screws holding in the battery box and pop it up in the cavity to make it easy to remove and insert the shock.
You need to remove the 17mm link bolt and the 14mm lower shock bolt.
to get at the 14mm shock bolt you need to knock out the link bolt and drop the links down
the stock shock comes out very easy once the two mounting bolts are out. You can see here with the battery box up it’s really easy to slip in the new shock If you don’t pop it up the res and mud flap will keep you from inserting it. The shock is a little tight going into the top mount but other wise it’s easy. Torque your bolts per the manual, reinstall all the other parts removed, and job done.
One note is that the stock bottom bolt is to short so you will need to use the gsxr lower mounting bolts. Mine came with a set so I was good to go. Also make sure you put the bolt in from the muffler side and the nut on the shifter side for the bottom or it won’t clear the links. The top is the opposite to mimic stock configuration
Looks good and just slightly rubs the rubber mat but clears the battery box by a few mm.
As expected the tank dosnt lift all the way but still enough room to get in and swap an air filter.
all in all an easy mod and since no modification is need I can always go back if I don’t like it. Now it’s time to ride and tune for rebound and compression. I set the shock to factory 750 settings.
