1 - 2 of 2 Posts
I have an 03636 on mine. I used the stock top bolt and nut. However the shock I had was off another SV, and the guy before me modified it by grinding 1/16'' off each lower side. This allowed it to clear the dogbones. I used the bolt and nut he sent me with the shock. I believe it was ground slightly as well. Hope that helps. Make sure you torque it down right too. These specs should be in a service manual.
1 - 2 of 2 Posts
