1 - 3 of 3 Posts
Ok so I'm having an issue with my rear brake light coming on, here's the catch I guess I swapped my tail with a 06-07 Gsxr 600 tail I spliced the Gsxr tail light harness into the Sv harness. My front lever turns the lights on and off but my rear pedal only sometimes flickers, any ideas?
Maybe a poor working rear brake switch. It is actuated by a spring which is pulled when you press on your brake pedal. Manually actuate the rear brake switch... see if still happens.
1 - 3 of 3 Posts
