Ok so the guy that put new tires on my bike brought to my attention that the rear pads were nearly gone..... so i got my new ones in from suzuki today and busted out the wrenches when i got home...... everything went about as smooth as working on a 20 years old motorcycle could go lol...... the caliper was froze at first finally got it moving correctly..... my plan was to remove the caliper completely and work on it however i couldnt get the damn bolt loose that holds the caliper in place that is in the end of the arm type part.....dont know the proper name...... (see attached pic).......so what i did was took the two bolts that hold the caliper on the bracket off and the whole arm was able to swing down enough for me to fiddle with it......... my question is........ what am i doing wrong with the first bolt i tryed to remove...... literally it is frozen.... is there a secret to it or has someone wrenched the damn thing down at some point and screwed me? And also can that being so tight it cant move affect braking in some way? Not sure if there is supposed to be some movement there? The other end of the arm had some play and i was able to move the thing down and work on it so im assuming that end should also move the same way??? Sorry if this is hard to understand
