1 - 3 of 3 Posts
Yes, if you are talking about some of the earlier (2003 & 2004) 2nd Gen S radiators that had a higher collar for the fill tube.
In fact, it's easier to service if you use the naked radiator on the S model. In later years (2005-Newer), they stop using the higher neck on S models, using the exact same one as the naked bikes.
I could never figure out why Suzuki designed the earlier 2nd gen S radiators with that neck, made no sense and was difficult to check/refill.
Fors forst gens, the n radiator does not have the tabs for the side fairings, which are welded to the sides of the s radiator. Not sure about second gens.
1 - 3 of 3 Posts
