1 - 7 of 7 Posts
is there any reason i shouldn't or couldn't bring my bent radiator to any local shop that does radiator work?
also, are radiators are aluminum, right? i just want to make sure i'm correctly answering the questions these guys ask me
I fixed mine, and works like a charm. But only reccomend it as a temporary fix. I see no reason why you couldn't take your rad. into a local shop.
99.9% of radiator shops won't work on an aluminum motorcycle radiator, and if they do, they just use an epoxy to plug the leak. I'd strongly suggest sending the radiator to http://www.motorcycleradiators.com/. They do excellent, excellent work and do their best to turn the radiator around fast.
Stranger my dad is a mechanic in Bergen county. I know he doesn't do radiators but if you want i can find out where he recommends locally.
that would be awesome! at the very least, i'd have other options besides motorcycleradiators.com to consider before making a decision
When I put a rock through the radiator on the Colorado trip last year, I ended up fixin' it with JB Weld. It's been fine for almost a year and over 10k miles.
Of course I have no idea how badly yours is damaged.
1 - 7 of 7 Posts
