1 - 4 of 4 Posts
I'm pretty sure 03 and 04 are the same. WIDE
The 05 and up will fit easily, but the fan is different, so you'd have to replace/modify that too. Not as wide as 03/04
A more involved project is going to a 1st gen. Fan space is really tight, (I went with a CBR pancake style) mounts are too short so there is some fabrication, cutting/grinding/filing, etc. to make it work. Also need 1st gen hoses and thermo switch. It's a bunch of work, but I'm pleased with the result.
i have an 04 sv650 and the radiator has a hole in it what all years will fit?
I just did a radiator replacement and found good an aftermarket part on ebay in the US shipped to me within two days for about $170. It has been performing better than than OEM at about 10 degrees lower.
You can find a bunch of the same units for about $100 with free shipping if you are willing to wait a week or two for it to get here from overseas.
It's an easy swap that can be done in a couple of hours tops.
Feel free to message me if you run into any issues or need guidance.
Good luck,
dave
1 - 4 of 4 Posts
