So you want to put a steering damper on your SV, but unsure which to use? Is that the question? And it sounds like you want to use a 'Pit Bull' style one on the top triple, not a side or front mounted long piston type, correct?
I want to put a radial damper on an 2k SVS. It has 01-03 GSXR triples. I have a damper unit for the '02 but and unsure about fitment to the GSXR triples. Specifically, there is an issue with something that is shaped like an uside down letter T.if i wanted to put a radial dampener on an 2k SVS with 01-03 GSXR triples would i still be able to use the dampener for the 02' sv or would i have to use the dampener for the GSXR?
if i had to use the GSXR dampener what would i do about the "upside down T shaped thing" ?
