1 - 2 of 2 Posts
I adjusted my chain yesterday as the dealer set it at 1/2" slack. I set it to 1 1/4" .
Anyway, obviously the shop manual is wrong where it says to torque the castle axle nut to 750 ft. lbs. I went with 75 ft. lbs. since that matched the metric measure.
In doing so I noticed that this was much tighter than the PO had it and also much tighter than the shop had it. I would have been fine with that, but it also meant that the nut is threaded down past the cotter pin hole. Not far past mind, but still...
Is this normal? I hope this makes sense.
Oh also I checked and the wheel spins freely as normal. Just don't want to crush anything on this long trip.
Thanks!
id back it off just enough to get the cotter pin lined up then it will be just fine. mine is set around the same and after 2000 miles im still doing good.
1 - 2 of 2 Posts
