That is incorrect - the bottom triple is also different.the only thing that defers on both is the top triple.
otherwise the same.
Really,That is incorrect - the bottom triple is also different.
There is a different fork offset between the naked and S versions
However the answer to the OP's question is valid, in that the fork legs themsleves are identical & can be transferred between models.
Really,
I have the top triple from a naked on my S with the S lower triple.
Troublemaker! :laughing4:I think we need to do some more measuring to validate D'E's claims. ;D
http://www.motorcycledaily.com/09april03suzuki2003sv650.htm.....This is the first I've heard of a difference in offset between the two.
Check the parts fiche - different part numbers for bottom triple all the way through the Gen2 range.Fork offset also differs between the standard model (26.5mm) and the 650S (28mm).
