After my last post, I thought my problem was fixed with the new battery, but as for my luck, it's never this easy. Here's my test result for rectifier and stator.
Diode test for rectifier, I don't know if my multimeter is broken, but result of "1" stays on the screen no matter which lead I test it on.
With bike running idle, rectifier outputs a pitiful 1.2 volts. Testing AC from three lead wires of stator shows about 20 V. Resistance test between the stator wires shows about 0.6 - 0.7 ohms.
I think both rectifier and stator are both fried, and while preparing parts for their replacements, couple questions arise:
1. Where should I get a stator. Ebay has 01 stator < $100, comes as a drop in replacement. But they ARE 7 yrs old. I also notice couple 03+ stator, anyone know if they will fit? Or should I go with after market with something from rick's motorsport like this:
http://www.ricksmotorsportelectrics.com/proddetail.php?prod=21-309&pmc=MDBTdXpTVjY1MA== Aftermarket one probably would need some additional work done like solder it to existing wire.
2. Gasket was broken when removing the stator cover. Is this the right gasket to be used, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260341579738 ? I have crossed check couple other sites and it seems to be right, but I would feel more confident with a confirmation from this crowd here.
As for rectifier, I just bought a 07 cbr1000rr one(should be here soon), will install it the same time.
Thanks a lot for any help and pointer you can give.
cheers,
Mark
cheers,
Mark
