Does anyone here know the specs/measurements on the bottom shock bolt for a 1st gen? I apparently misplaced mine and don't want to deal with the dealer if i can avoid it. thanks in advance.
For the 2nd gen I'm pretty sure it's a 10mm bolt that is 50mm long. I would think it's the same. Maybe someone can verify.Does anyone here know the specs/measurements on the bottom shock bolt for a 1st gen? I apparently misplaced mine and don't want to deal with the dealer if i can avoid it. thanks in advance.
Correction grade 10.9 for metric.Make sure it's a grade 8 bolt, you should be able to find one at Lowes or HD.
The bolt and matching nut doesn't need to be metric, it just has to fit thru the holes on the dog bones and shock.Correction grade 10.9 for metric.
Wow they really F'd up those 2nd gens didn't they. :nana:I don't know about 1st gens, but on the 2nd gen the lower shock bolt threads into the shock, so yeah it matters.![]()
Mine didn't.I don't know about 1st gens, but on the 2nd gen the lower shock bolt threads into the shock, so yeah it matters.![]()
Stock shock does; replacements (gsxr, ohlins, etc) do not.Mine didn't.
That is weird. On Ronayers they are showing it with a nut and bolt too. :confused5:Mine didn't.
My bad you guys were right, I just pull out my stocker and sure enough it had a small threaded section. I r retarded.Stock shock does; replacements (gsxr, ohlins, etc) do not.
We know. We were just trying to be nice. ;DMy bad you guys were right, I just pull out my stocker and sure enough it had a small threaded section. I r retarded.
