2003 Suzuki SV 650
03 SV 650. From the parts diagrams the 03 to 08 fuel pumps look similar. 05-08 having two thermistors. Can I just ignore the upper thermistor?
Do I have a wider field to pick from, since mine is toast? Wires rotted out of the pump, thermistor, and it is frozen.
2003 Suzuki SV 650
Discussion Starter · #2 ·
How about the Kemso fuel pumps, allegedly made in japan on flea bay, and the ebay thermistors? Which non oem pump chooches well? I am not geeting offf of seven benjmins for a pump on a yard sale bike. And the used prices are a joke.
Any gen2 fuel pump will work on your '03.
'03 and '04 will be plug and play. (single fuel level)
'05+ have dual fuel level thermistors so the extra thermistor needs to be disconnected. This is easy to do by swapping out the wires from the 4-position plug on the '05+ to the 3-position fuel pump plug on your '03. Tape off and zip tie the extra thermistor wire.
Do you have a part number or link for the thermistors?
Not to be a fearmonger, but I would not experiment with non-OEM thermistors. The SV650 fuel thermistor needs to handle about 4 watts. If the wrong sensor (too low wattage) is used, it is possible for it to get VERY (red) hot. Hot enough to ignite gasoline vapors? I don't know, but with the fuel tank sitting between your legs, you probably do not want to find out! : -)
There are a million NTC thermistors out there with all kinds of voltage/current/watt ratings. Most are NOT designed to be used in gasoline.
The best bet is to buy OEM from the dealer. Used ones are on eBay for less $$. Some sensors are single thermistor; some are dual. If you only have one failed thermistor, you can buy a dual thermistor stalk, remove one thermistor, solder that in to replace your failed one, and have a spare left over.
Good luck and welcome to SVRider.
