To me it looks like the bolts too short and you havent got the nut on the end, but i have been known to be wrong quite a few times ;D
That's what I was thinking too, but that's how it was with the stock shock: short bolt, no nut. The upper has a long bolt and a nut though.To me it looks like the bolts too short and you havent got the nut on the end, but i have been known to be wrong quite a few times ;D
The Elka does have a threaded clevis. Hard to tell if the threads are stripped, but it would make sense if they were. I'll try to find a longer bolt & nut to try. Looking at it now, there should still be room for a nut next to the dogbones.hmmm it could be stripped out if it just spins and spins, if you take the bolt out look at the threads in the shock clevis make sure they are ok. If it is stripped you can get a longer bolt and nut, but it might have to be a low profile nut to clear the dogbones.
edit: Im guessing the elka is like the stock shock and my penske witch have the threaded clevis.
