1 - 20 of 27 Posts
Can you use a 93-95 GSXR 750 front end. I know it is not adjustable, but it is inverted has 4 pot calipers.....
hmmm.....I am thinking about partingmy 93 GSXR out instead of building it. This might be the decision maker--usable SV parts for modding
go for it. gives you something to do...
off topic but what kind of tail section do you have i like the looks of your bike.
I know the SRAD is 19mm shorter than stock. Any specs on the 93-95??? I can take measurements.....I am rally excited about this working. All I need is another SV to build LOL
I think older ones are longer.if I can remember,gsxr1100 has longest forks.it is been long time and I may be wrong.measure it.
I measured from the top of the fork to the bottome. 28.5" Fork OD is 52.75mm
Distance between forks 6.5"
Nissin 4 pots and a different axle than the SRAD
I did it with a 97 750 and I kept both the stock triples, also still have steering stop, and speedo use, oh did I mention key lock! You do have to use the gixx wheel, roters, and fender though. Same brakes.
it was the easyest thing I have done. My bike is an 03 sv1/2s
You mean the GSXR triples, right?
No I used my SV triples. I've gone 1000 mi on it already and it seems fine. I hope I didn't do something wrong.
Discussion Starter · #14 ·
huh??? how did you squeeze the forks through the triples. 41mm doesn't = 52mm
Is it a USD or conventional fork?
bought the front end of A Bike, for $325
are you sure!, they came with upper and lower triples, front brake system, fender, wheel/ w roters and axel.
if it is then oh well, my old one's were bent anyway. Well the left one.
1 - 20 of 27 Posts
