does anyone have one put on their bike. is it worth it or not. i want to get a k&n air filter, i already have a pipe and i was just wondering if anyone had andy experience with them. when i got my pipe i asked the guy about re jetting and he said no not with a bolt on. should i do it??
It helps make a few more HP. The best upside is that it smoothes out all the stumbles.
You only live once, might as well get it.
I wouldnt have an aftermarket pipe / AF without a PC, I reccommend the PC3. Plus you can adjust it on the fly with a 9 volt battery, or hook up your laptop to your bike and custom tune it if thats your thing. If you live in a low elevation and then do some rididng in a higher elevation, or vice-versa, you can adjust your fuel mixture to lean or fatten it up as you need to.
Get one its worth it.
Woody
first of all..yours is an 05 so u cant rejet its FI. Second...yes...get the powercommander..its worth it. I got mine for less than 300...had a custom map made....runs very smooth and I get 75.1 hp out of it
I got both the drop in K&N and the slip on.
From the 2 alone my bike gained about 15mph on the chrono on top end.
Defenatly interested in the PC but can't afford it right now.
