1 - 10 of 10 Posts
Anyone know what size socket is needed for the spark plugs? The plug socket I have (5/8ths?) doesn't seem to fit and the manual just mentions a tool number.
Help.
I don't know it off the top of my head but do you have the one from your bike tool kit? You could measure that one...or use it!
Tried that. Nothing in there fit.
Of course I did lose a few pieces on the road when my bike was new. If you don't completely secure that little door to the tool compartment, it WILL fall off. Took me a few miles to figure out what that clinking sound was on left turns. Sigh.
It's a 5/8" socket. Make sure you get a deep socket though - preferably a spark plug socket that has the rubber gromet inside to grip the plug on removal.
Yeah, I've got the craftsman 5/8 spark plug-specific socket with the rubber inside. I tried using it along with an extender and could get hold of anything. At least I know what size it is for sure now. Thanks!
If you aren't lined up evenly the tip of the plug may not be going into the hole in the rubber thingy inside the plug socket. Use a regular deep socket.
THe tip of the plug could actually be topping out the socket. If you just drop the socket onto the without a wrench, you'll see if the plug pokes through. If it does, your socket isn't deep enough. You can still get the plug out, just don't put the 3/8 drive all the way into the socket. Be careful, it could pop out.
Have a magnet handy to pull the socket out.
And when reinstalling the plugs it a good thing to have some really long needle nose pliers handy because sometimes the socket will stay on the plug as your trying to pull it off. :eek:
1 - 10 of 10 Posts
