Okay so yesterday I pretty much had half a track day wasted because I couldn't get my rear wheel back on properly. :angry1:
After I put the axle back in, I make sure the chain is adjusted to spec and the wheel is aligned. The problem is once I get it there, the right side adjuster is loose. I can wiggle it around inside the swing arm.
I tried stick a rag in the chain/sprocket and it helped a bit but It still wasn't right.
What am I doing wrong???
This is with the nut tightened down? Any chance you're missing a spacer?
You're 100% sure you can't push the wheel any more forward with the axle nut loose? If you push forward does the adjuster tighten up?
Technically, if the chain is in spec, and wheel is aligned properly, the axle should hold it in place. Tighten up the adjuster once the axle is torqued down
unless I'm mis-reading this
Do you mean the spacers on each each of the wheel? I have those in place.
I thought I might be okay but it doesn't seem right to me. I don't like doing things half-assed, that's when murphy shows up.
I tried pushing on the wheel while adjusting them and still no luck, still had a small jiggle. I'm going to wait for my mech friend to help me.
Does anybody else have any comments before we go at it. :ears:
Don't forget the spacer inside the sprocket carrier. I had a shop forget to replace that one when they changed tire for me (never going there again) and they ruined my wheel bearings as a result. during the three days i was riding on it that way (didn't know better) I had a hard time getting the chain adjusted correctly. It wouldn't stay where I left it.
Could be the same issue you're having?
