1 - 11 of 11 Posts
Ebay item, seller says it's from an '02 SV650S, but it doesn't look like the others I've seen (note the sweeped back edge of the spokes)...
Yes. Katana front wheel. I've got a set (front/rear) in my garage I'd sell you for much less than ebay.
yes Katana wheel. i have one on the front of my '02. goes straight on. same speedo, spacing, brakes etc.
That's the key info right there... I'm planning to put it on an '01 SV650S. Just want to make sure it will go on with no mods to front end.
Thanks for the replies.
FWIW: This wheel is not the same. The bearings in that came with the wheel are bigger than the axel. I have replacement bearings, but the pocket that holds the bearing is bigger too.
Not anymore - this stuff was pre-SRAD (1100's and 750's). I used to have a couple once upon a time - no more.
1 - 11 of 11 Posts
