1 - 20 of 29 Posts
· Registered
I bought my trackbike last year and it had Dragon Supercorsa pros on it. I'm looking to replace them and could have sworn I saw SC2 on the rear and SC1 on the front but now that's worn off I guess because I can't find it at all. Just curious what you guys run on here before I order a set.
· Registered
70 degrees is really cold?! I've used SC2s in the 40's and even 30's! Hell, a few years ago in April I raced on rain tires when it was snowing.
· Registered
try a sc2 front and you wont run the sc1 anymore. i even like the yellow sc3 fronts better. and i never run a sc1 rear. its actually the old compound, while the sc2's have been updated.
· Registered
i never had any wear issues either, but i like the stiffer carcass on both the sc2 and sc3 better. both are better under braking for sure, and i didnt see a difference in grip either. i ran the sc1 front for years. then i finally tried the sc2 like all the big bikes had switched to, and i picked up a few tenths here and there at every track. if you guys try it, you'll like it.
i only ran the sc3 in endurance, but again, i really liked the way it felt. i know several really fast sprint riders that prefer the sc3 in sprints. moose told me some time ago, that dunlop riders that switched to pirelli liked it because it was a stiff carcass like dunlops.
· Registered
The popular set-up for the Dragon's at Loudon is the SC1 front, SC2 rear.
If you can still see the colored line on the meat of the tire (see below), SC1 = blue (supersoft), SC2 = green (soft) and SC3 = yellow (medium).
Don't forget to use your local Pirelli representative (Degsy) as a knoledgable resource ;)
This is a DIABLO supercorsa, but you get the point. Even if the tire is scrubbed in you may still be able to see some of the line down in the grooves.
· Registered
Just thinking out loud here, but, I'll try the Diablo sc2 this year. After riding a couple of the new Diablo sc1 fronts, i think like the old Dragon Supercorsa sc1 better. The new Diablo - its hard to describe - but feels a bit slow and not as responsive, but once its over it sticks well. I thought i felt it right away at pit speed, but it could be that **** wera required steering damper i'm not fond of. Its just in the that transition, gray area, i'm talking about...and Kris is probably right the carcass is a bit soft.
· Registered
tires are all about feel. if you dont like the way the new tire feels, and you're not comfortable, then you're not going to go fast on it.
i was a good test subject for it. when it first came out, i was at the barber national, i think it was 07. it had rained on sunday morning, and i didnt have any track time at all on the diablo front. pirelli adsured me to just slap it on, go out and ride it like i did the old tire, and i'd be fine. that was the first time i did 36's at barber on the sv, and i won the national, beating dane westby. i absolutely loved that front tire.
i cant tell any difference in the rears. pirelli told me they (meaning 160's) were the same tires as the old dragons anyway, other than some slight compound changes.
· Registered
Discussion Starter · #13 ·
So Kris you're talking about using a Diablo Supercorsa for the SC2 front? From looking around on google I'm guessing the Diablo's are the closer to race tire?
And thanks oreo that might just be the solution since obviously most of my time is at NHMS. I actually PMed Denno for a price, I'm not that close, but if the price is right it might be worth a weekend ride.
· Registered
i'm referring to the race dot, which is the diablo supercorsa. i dont know anything about trackday tires.
· Registered
I just wanna note that the Dragon is the old race DOT & the Diablo is the new race DOT.
Or were "marketing" the Dragon as a track day tire last year? ???
I dunno... Either way, they're still both technically Race DOT's as far as I know.
· Registered
Diablo Supercorsa SC2 front & back for me at the few NESBA days I run.
· Registered
I use the same set up here in fla with no problem,going to Homestead 3/29 for a trackday and going to use the same set up as always.
· Registered
Do you guys run a 120/60 or a 120/70???? The Michelin guy says I should run a 120/60 on the front. I need to buy a set of DOT's before April 25th weekend at NHMS but not sure what brand to go with. Michelins are mad cheap. Dunlop and Pirelli not so much. Bridgestone is right in the middle.
KB
· Registered
KBizzle, I think i'm runnin a 70. Ask Degs what he gives me :p
I'm all about the Pirelli's. BostonMoto are THE guys to go to at NHMS. They friggin rock.
Sup Oreo?!!!
THE guys at the track are THE guys that have the best price on tires. Once I shake down the SV and get used to it maybe I'll spring for a real set of tires.
I'll be happy if I can at least keep my times from the motard to the SV.
KB
1 - 20 of 29 Posts
