1 - 20 of 40 Posts
What would be the best rear shock upgrade for the money for the SV650 Naked? I think im going to go with progressive front springs, so just wondering what would be the way to go with the rear shock?
Penske Triple clicker, but I'm biased ;) Or you could just do a GSXR or 636 rear shock swap.
Im thinking about going with a GSXR shock swap, I think that would be the cheapest if I can find one.
best and cheapest arent terms that are exclusive to one another.
Instead of progressive fork springs just get some straight-rate springs from www.sonicsprings.com
Yea the sonic springs look pretty good. How much do you guys think a GSXR rear shock would cost, or some of the other performance shocks?
Should I go with 20W oil in the front or less? I have heard that a less weight oil such as 10w or 7w would give you better feel for the front end.
GSXR - 30-60 used on Ebay
Ohlins, Penske, etc. - 800-1200 new depending on model or find one used for 500-600 and get a spring for your weight for another 100.
If you can swing the cost find a nice used or new Ohlins, Penske.
Used penske double--
IMO the triple is unnecessary on a SV650 especially for a street bike--
but if you have the money and like tinkering with things..
7 or 10w oil isn't thick enough for the damper rod forks in the SV, you won't have enough damping. 15w is the bare minimum, and if handling is a priority then 20w is the way to go.
Oh, and I recommend Sonic Springs too. The owner's kind of a jerk, but the springs are good. ;D
Discussion Starter · #12 ·
Ok then ill probably go with the Sonic springs in the front with 20W oil. Im going to try and get a GSXR rear shock for under 100 if anybody knows of any. Also do I want a .90kg/mm or a .95kg/mm?
How heavy are you?
You might want to consider saving up and simply buying a good aftermarket shock instead of putting a GSXR one on there. You can buy a new Penske Sport shock from Traxxion Dynamics for $600 which is strung and valved for your weight, and will bolt right on. I've used the stock, a GSXR, and a Penske two-way, and as much of a jump it was in performance going from the stock to the GSXR, it's an even bigger jump going to a properly sprung Penske.
I just received a Cogent shock from Cogent Dynamics
www.motocd.com
Rick and Joyce were great to deal with. The shock is only adjustable for spring preload and rebound dampenenenenenenneing, but I figure the less variables in the equation the better for me. I'm slow, and am not a suspension wizard. It looks a quality bit of kit, and only cost me $501 shipped to my door (group buy price). It also has a small bit of height adjustability.
http://forum.svrider.com/showthread.php?t=96465
Discussion Starter · #15 ·
Yea for that much money though, I would just put it twards a better bike. Im trying to get a rear shock for under 100. Thats why I am looking at just doing a GSXR swap. Dont get me wrong the SV is a great bike, but mines a 99. I just dont want to drop that kinda money into it right now. I wont get anything back for the bike and in a few years probably going to get a supersport. So just trying to get the best out of it right now without spending a whole ton of money.
Discussion Starter · #18 ·
Ok ive got everything figured out on what Im gonna get, Im going to go with the sonic front springs .95kg/mm, with the 20w oil. Then I think I am just going to leave the rear spring stock for right now, I just dont want to drop that much money into it at the time being. Thanks for all your help guys!
site supporter
Without saying how much "the money" you're talking about, your question makes no sense. I did a 636 shock last year. It cost about $60 and improved the ride and feeling of my SV. An Elka or Penske would be better. Outrageously better. But that would be boucoup de bucks.
First, you don't want progressive front springs; you want linear. Read this on Sonic Springs' website, as to why:
http://www.sonicsprings.com/catalog/straight_vs_prog_tech_article.php
In fact, you want Sonic Springs. PM RichDesmond, he'll answer all of your questions and hook you up right.
As for the rear, if you can find a used high-end race shock (Fox, Penske, Ohlins) for cheap, that would be ideal. Try the WERA and NESBA boards.
None of the OEM swaps for the first gen SV are ideal; best bets are the Kawasaki shocks -- 636, ZX10, ZX12, ZX14.
1 - 20 of 40 Posts
