Just got done with my Penske install. I have a couple of questions.
I want to know if the reservoir is located in a safe place. I have it attached to the bottom of the battery box on the leg hanging down. I cut 2 slits and put the brackets thru. Seems to be tight and a nice fit. The plastic did bend alittle but did not tear.
Is the reservoir in danger of stones or water? I'm looking at other options on where to locate it.
Another question, Can I get a longer hose connecting the shock to the reservoir? Can I change it or does it required other things to be done that I'm not aware of?
Thanks
Thanks
