PDM60 6 circuit Power Distribution Module
Comes ready to work as originally Factory pre-programmed OR with the included unique cable you can custom program with your PC the individual circuit capacities and various other functions. No fuses, you determine the trip point of each circuit from 5 to 20 amps as well as on/off delay of a circuit if desired and whether the circuit is switched or unswitched. (Grip heaters might be switched so you can't forget and leave them on whereas a GPS you may want it to be unswitched so you can sit and plan without the key being on for example). LED indicator for each circuit -- circuit tripped, circuit active or circuit inactive. Weather proof, mounts anywhere that you want. Original packaging and manual included. $150 SHIPPED
Revzilla review
PDM60 You Tube
Revzilla review
PDM60 You Tube
