1 - 7 of 7 Posts
Hi, I was messing around with the tail end and now when I turn the key to release the passenger seat, nothing happens. I've read that people have used a coat hanger to manually release the seat. I've tried and I can't seem to find the release. Can someone help explain where the release is? Thanks!
the mechanism is located centrally along the front edge of the pass. seat. a cable runs from the lock to the hook that holds the seat in place.
when you turn the key, try lifting up on the front of the pass seat. it could be the lock is releasing but the spring is just not popping the seat up.
actually, #9 is the cable, the lever is in #7, where the other end of the cable attaches.
You may want to take off your seat and take a look.
Cable must be pulled where it hooks in or riders seat must be removed to get to the other end.
A hanger from the left helmet hook could work if you are good at puzzles.
1 - 7 of 7 Posts
