So I did the PAIR system delete a while back after debaffling my stock exhaust. Didn't do the entire removal (thankfully), just plugged the one hose.
Recently moved to the Phoenix area. Went to go get my emissions inspection to get AZ plates. Failed for a high CO count. Did some reading on the PAIR system and it seemed like that was the likely culprit. Unplugged that one hose, and brought the bike back for a retest on the same day. Passed, no problem.
So, the take away is that if you live in Arizona (or some place with stringent emissions tests), you may have a problem passing the emissions testing if you do the PAIR system delete. In Pennsylvania I don't believe they even tested for emissions so it was never a problem before.
Something to consider before you do that mod.
--Jeff
--Jeff
