81 - 100 of 140 Posts
· Vendor
Even at 90%? Remember, I'm in the jungles of south Louisiana.
I will see your Louisianan humidity an raise it! Houston certainly has plenty humidity to spare.
Humdity is a factor, but it is far less a factor than it used to be. Any paint that "cures" by solvent drying only is effected to some degree ( any laquer based paint be it nitrocellulose or acrylic mainly ). Pretty hard to get enamels to actually blush. Dry coats don't blush as easily. Blush is caused by trapped solvents under the surface of the paint. Any catalyzed paint dries mainly through chemical reaction so solvent trapping is hardly an issue.
Spray cans....well who knows what is in them!
· Registered
2000 SV650 N
Discussion Starter · #84 ·
True, Houston can be brutal. Just for grins, while awaiting the clear I'm going to practice with the paint on a scrap piece as you guys suggested. I need the practice, and it will encourage me to put together a paint area.
· Registered
2000 SV650 N
Discussion Starter · #85 ·
With curiosity getting the better of me, I chose the fender again as my test bed. While I don't have the cleat yet, I figured I can try repainting the front fender with base, using the advice I've received here. Specifically, paint out of the wind, hit it wet, and paint the next coat while tacky. I know I will have to re-sand and paint the base coat again when the clear comes in, but a little practice can only help.
As you can see in the pics, the paint went on much more uniformly. The metallic bits are spread evenly, and the coverage is not splotchy. All in all, I'm please with the improvement. However, I'm surprised with how dull the paint is. It looks almost flat. Maybe the clear will address that?
Plant Hood Helmet Automotive lighting Bumper
Fender Automotive design Gas Automotive exterior Bumper
  • Like
Reactions: Jay V
· Super Moderator
(SNIP)
Dull is good - for a base coat.
The gloss level of the clear will determine the final finish. The gloss of the base has no bearing on the final gloss.
· Registered
2000 SV650 N
Discussion Starter · #88 ·
That's a relief, but that's what I suspected. I'm pleased with the uniform coverage. I expect my clear tomorrow. So. hopefully I can then wrap up.
· Vendor
Is that paint labeled as a base coat? If not...I have no idea how it could be so flat ( gloss free ).
Still, practice is GOOD!
· Registered
2000 SV650 N
Discussion Starter · #91 ·
It is not labeled base coat. But on their website, Dupli-color outlines the three steps required for best results. Basically, prime, color coat, clear.
· Registered
2000 SV650 N
Discussion Starter · #92 ·
Painting silver metallic has been quite a learning experience. I've practiced on the front fender, and am getting the hang of it. My 2k clear arrived last night, and it looks like the rain will hold off until Saturday. Temps should be in the high 70s, with relative humidity around 60%. I took the rest of the week off from work, so I plan to paint the whole bike today. Fingers crossed.
  • Like
Reactions: Jay V
· Registered
2000 SV650 N
Discussion Starter · #95 ·
Degreased and wiped everything down with tack cloth. The base color coats went pretty well. The coverage was not as even as I would have liked, but I knew from the beginning it was not going to be perfect. Then I made the mistake of trying to even the tank coverage out with one last coat. It went from pretty even to pretty crappy.
Window Window blind Wood Stool Floor
Automotive tire Motor vehicle Hood Vehicle Table
Helmet Automotive lighting Automotive tire Fender Cookware and bakeware
Helmet Headgear Personal protective equipment Fender Automotive design
Rather than trying to "fix" it more, I rationalized that the waves of metallic would give it character. I then further convinced myself that the clear coats would make the waves seem less noticeable.
· Registered
2000 SV650 N
Discussion Starter · #97 ·
The clear went better than I anticipated, although it did not cover up my base color screw ups. But with so much shine, I can live with it.
Helmet Automotive lighting Automotive design Automotive exterior Headgear
Helmet Automotive lighting Fender Gas Aircraft
Automotive lighting Idiophone Automotive design Automotive tire Motor vehicle
Hood Motor vehicle Automotive tire Automotive design Automotive exterior
Helmet Sports gear Automotive design Motor vehicle Fender
Fin Wood Fish Shark Requiem shark
Overall, I'm pleased with the results. In hindsight, I should have gone with non-metallic white, given my rudimentary tools and lack of skill. But it is 100% better than the crappy paint job done by the PO, and as Salty said, it's worth so much more if you do it yourself.
Thanks guys for all of your advice and encouragement, especially Shelby, Salty, and Jay.
BTW, one thing I noticed with both cans of clear. When spraying with the can tilted, say on the top of the tank, the nozzle acted up, jumping from a fan-shaped spray to a round one. This was even with full cans. I thought it may be a defective can so I opened the other one, only to experience the same thing. It was frustrating.
