1 - 15 of 15 Posts
i recently wrecked my 02SVS and was cuirious as to if i should replace it with a race style tail section or just put it back to stock.......any opinions?
thejimdaddy said:
that is really up to you, you carry passengers, then a stock would be better, if not and don't mind the loss of storage then go race tail
Couldnt have said it better.
is there a significant price difference between the two?
depends on where you buy, on ebay tail plastics are pretty reasonable, depends on the color too, blue seems to be a little higher than the silver, the race tail might need some additional fabrication it work on a street bike, i'm not sure, i'd personally go with a seat cowl with stock plastics
hmm what kinds of mods would i have to do for the race tail to fit?
i'm not sure, but anytime you put a nonstock piece it never fits as well as OEM, plus it was meant for race, IE no taillight undertray, it just might not be a simple job, it's probably not hard either, just something to consider
Generally you have to drill all the mounting holes, possibly re-route some of the wires outside of the subframe, and make it work with your undertail. Some of them come pre-cut for a tail light, others dont. Price ranges from 150-225ish, whereas with the stock tail you could replace just a half of it if that is all you destroyed. But they look so bonerific.
for some reason in the crash it destroyed both sides although my right front uppers, and lowers were untouched. I was so out of it after i crashed i didnt think of looking for scrap lying around........i even managed to "kung fu" kick my way through one of those 4x4 road signs
Discussion Starter · #13 ·
everything still looks pretty straight. Is there a special way to make sure that its ok?
String.
From the headtube to the back of the bike.
Measure the distace at some point in the middle. If its not the same on both sides, something is tweaked.
i'd go with a 1 piece solo race tail
the SV650 tail plastics are peices of shit-they are SO Easy to break(3-piece design)
thats the only thing i ever hated about mine
actually for some reason i've had bad-luck with all suzuki's tail i've owned-lol
the gixxer tail is 1 peice but still cracked for no reason around the mounting holes
1 - 15 of 15 Posts
