1 - 2 of 2 Posts
On a past from somebody had said to wire into the horn(in case of not turning off the heaters it would'd drain the battery).
If I do this witch wire to the horn do I use the black/blue tracer or orange/green tracer?
Or does anybody have a different way?
I may have told you that, because that is the way I have done it. You have to figure out which one is hot with the horn button pressed..the other is just the ground. Just use a tester and it should take two seconds to figure out. It is most likely the orange and green.
1 - 2 of 2 Posts
