1 - 8 of 8 Posts
Hi guys,
During a track day, I crashed... marshalls had to flip my bike over to let my leg free from under the bike. (I'm ok, don't worry!) Bike was mechanicly ok, instead for this:
For the rest of the day, my bike did some awful blue smoke (oil burning).
What will I have to do to get rid of this problem?
Thanks in advance!
Most likely;
Oil ran through the crank case breather,to the air cleaner.
Wipe it clean inside,and the rest should burn off.
You can also take the plugs out and unplug the fuel injectors and crank the crap out of the bike so it pumps the oil out.
If you've been running it, the combustion chambers should be pretty well burned out by now. But...I agree if it is continuing to smoke it is probably coming out of the airbox. Do you still have the PAIR hooked up? Oil in the box could be feeding that...which will smoke like the devil.
I'll pass the word for sis brake fuild! ;)
You guys were right! I open my air box... about 1/4inch of oil in there :S ...
Drain all this out and now I'll clean my K&N air filter to finish the job!
The smoke is still coming out but, very much less, it will surely stop smoking after sometime!
I have also check both spark plug to make a diagnostic using those. No oil on them, clean run, so I think it was only oil from the air box that was feeding all this smoke problem.
Just receive new pics from my crash...
1 - 8 of 8 Posts
