1 - 3 of 3 Posts
doing a track-day tomorrow so I figured I'd throw in some fresh rotella,
pulled the fill cap off then pulled the drain plug and all I get is a small trickle then a couple of small drops with the bike straight up. Sight glass is still half full and when i tip er over all i get is a tiny trickle of oil (not dirty or contaminated). What gives? anyone ever had this problem.
Discussion Starter · #2 ·
nevermind, I pulled the wrong fukkin plug ::). I pulled the one to the right of the filter just above the pipe- what is that plug for anyways?
just plug for hole.they drilled oil gallery through case and had to plug it after.there are few more around,every bolt that has washer under is gallery plug.
1 - 3 of 3 Posts
