1 - 8 of 8 Posts
I have an 03 SV650, and noticed that my oil cooler is slowly seeping oil on both sides (over the cylindrical columns)... well much more on the left side than the right side.
Here are pics (see the wet-looking area, this was after I cleaned/dried the engine, and after 1 session on the track):
Has anyone experienced same issues?
I assume I just need to change the oil cooler?
Does the SV1000 have same oil cooler? Can I swap that with mine?
Thanks
well, the oil is not coming from the plug... it's actually coming from the top/side of the oil cooler and seeps downward
Doesn't matter where it leaks from if it is in the trash.
We meant remove the cooler and the hoses forever. Use the TWF or honda plug for the 2 holes that are left in the engine. Shezam...2.5 lbs lighter and problem solved! The older SVs didn't even have oil coolers.
Here's a thread arguing both sides...http://www.svrider.com/forum/showthread.php?t=154741
Or keep it, whatever you want. :)
It doesn't hurt to have cooler oil, especially since the 03+ had a little more power. But tons of people run without them since they have a tendency to break in many crash situations. I personally don't want a rock to hit it and have oil spray all over the track.
I got a perfect replacement on eBay for $30 + shipping.
1 - 8 of 8 Posts
