I found a 514 lb/in spring on ebay, ordered early last week from a guy in Albania ffs! & it arrived on sat.( DHL FTW !!) ...my target spring rate is the next one down the list a 542 Lb/in.
I was able to pull the longer (190mm) lighter spring off using a cheap compressor (yes, it was a PITA, but it worked & I have all my fingernails!) and swap the shorter 170mm spring on cleanly.
I am running a spring that is 30+-lb softer than " i need " based on Penske chart.
I am wondering about spring rate targeting based on rider weight only. esp when you are within 30-35lb of the target spring rate..?
What about rider skill / average speeds / Street or track use / rider aggression etc, do any of these factor in...?
..given how many ppl. ride these for years with minor/no mods,....I am trying to understand how big an issue it is to run a slightly soft spring...? Is it a big deal or am I close enough that it'll work just fine,....?
I mean,..I'm building a custom properly equipped weekend carver/cruiser, not a racer.
I am also losing weight each month & plan on dropping 30-35 Lbs+. which should put me down at a weight this spring rate should work perfectly for...
I'm setting it up as described in the shock literature :
I'll keep the ZX shock, pull the 543lb/in spring to check if it fits on the Ohlins.. .if so ill keep it for a while and see how the 514lb/in spring works if it seems like I need a heavier rate i'll have a spring ready to go.
OK!... ;-) It is dialed and ready to install some time this week.
- 13 clicks out on compression
- 12 clicks out on rebound
- 13mm of preload from snug/free spring
- Shock length set to 338mm
