My PCIII died a while ago and I've read enough reports of them die'ing that I was leary about buying another. I also used to spend a lot of time on XLforums for my Sportster and the Cobra is very popular with them, and I haven't seen any problems with them. The Cobra is also ~$100 less expensive. I got mine new for $200 shipped via "GM Cycles" Ebay store.
The install appears to be on par with the PCIII but configuration is done with a set trim pots (switches) that you can adjust with a screwdriver. While this is much easier to modify mapping, it PCIII is definitely more flexible... assuming you are capable of writing your own custom map.
I should have it in a few days and will ducument the install and configuration.
