1 - 4 of 4 Posts
After researching previous post, I understand the speed sensor frags out but that couldn't be the case if my odometer was working, correct? So that leaves the most probable cause as a loose or corroded electrical connection?
I wanted to run this by you guys for your opinion before I start rooting around for the issue.
Thanks in advance
Yup, time to look inside. :)
The exact same thing happened to my truck speedo last year. I logged into toyotanation.com and found a thread describing how the solder joints to the speedo drive coil often crack with age. Took the dash apart, re-soldered the coil connections, and problem solved! Man, I was so happy! :rock:
You may have a similar problem, JCrow, though it is not a common complaint on the SV. Please let us know what you find.
1 - 4 of 4 Posts
