Status
Not open for further replies.
1 - 20 of 26 Posts
NOMINATE your favorite bike, SV650.....SV1000.....Gladius!!
This will be for September 2012 and these are just the nominations the voting will be started around the 20th.
Rules if you need to know.
SV of the Month Contest Rules
The SV of the Month contest is here! Time to recognize SVRIDER members and bikes that are truly outstanding. Each bike that wins will be featured on the front cover of SVRIDER.com the following month.
Here are the Rules:
- The contest is open to the SV650/S, SFV650 and SV1000/S's ONLY *
- You MUST be a MEMBER to win
- One nomination by any MEMBER and a second from another member makes you eligible to win *
- Nominations must include the name of the member being nominated and a photo
- You may only nominate one other member per month
- You MUST have at least 20 posts to be nominated
- You CANNOT nominate yourself. If you do, you are ineligible for the month in which you do so.
- You can only win once in a 24-month period *
- Nominations will be accepted from the 8th to the 14th of each month
- Voting will be held from the 15th to the 21st of each month
- Nominations will be limited to a maximum of 10 bikes per month. If too many are nominated, it is moderator discretion as to whom to drop. *
Discussion Starter · #2 ·
I just realized the thread was spelled wrong.
Also I'm a little bit behind this Month and my helper mod doesn't seem to be in the vicinity right now. So the nominations will be open till the 20th, then I'll make the voting thread.
nominate dmnyc
good luck to u all
2nd fatpad
Looks like it will be a good selection of bikes this month.
2nd apexr7
Discussion Starter · #19 ·
I nominate pronator
1 - 20 of 26 Posts
Status
