1 - 3 of 3 Posts
Hi guys,
I installled a PCIII a month or so ago on my 05 SV1ks. I have felt that it was running lean around 3-5k, so I increased fuel on my map.
When I went to load the map I realized that the PC is not registering any changes in TPS. I can rev the bike, and it follows the rpm, but reads only 0% throttle. Is this a synching issue, or is something f'd up?
My PCIII was made for 2003-2004 SV1000 and did not come with a wire tap like the 2005-2007 one does. I was told the PC's work on any models, but obviously this is necessary.
Any ideas on getting around this?
Discussion Starter · #2 ·
Used PC software to synch TPS, and it seems to at least fixed the lack of signal.
I noticed that every time I load a new map, I have to reset the TPS, otherwise it reads 0% throttle throughout.
The bike runs MUCH smoother now that it's actually getting a somewhat decent A/F
I don't know about the PC in particular, but my FI system in my Triumph requires a TPS reset every time when you load a new map into the ECU. Probably needs to be done for all systems when a remap is done.
1 - 3 of 3 Posts
