1 - 3 of 3 Posts
no neutral
Hi everyone, quick Q...my bike will not go into neutral...it feels like it does but the second you roll the wheel it slips into gear...from1st it slips into 2nd, from 2nd down to first, and when the bike is running it does the same thing just really fast. also the neutral light on the instrument cluster does not go on even for a split second which is really wierd. So far Ive tried adjusting the chain and clutch, trying it cold and at operating temperature, rolling it around, on the stand...etc.
Now, I did do something bad! ...I layed the bike down accidently whille i was installing a new clutch cable and had the gear shift lever and the clutch cover off. I have frame sliders and the footpeg to protect that area, but i have to assume something happened because this was not a problem before that. If the clutch rod was jammed or bent, that could be the problem, but it does no appear to be damaged. any help would be apreciated, thanks! :ears:
1 - 3 of 3 Posts
