1 - 4 of 4 Posts
I bought a 2003 SV 650, a couple of months, in bits. It had a seized big end which the guy said was due to blockage in the oil gallery. Coincidentally, it had an ample supply of very clean new looking oil so i'm a bit sus that he ran it dry. Anyway,I digress. I have bought another engine and put it in ( a sinch for a 63 yr old bloke by himself) and am about to hook everything up but I can't find the number 2 coil. I have found what I believe is the number 1, by the length of the H/T lead, on the LH frame rail but I can't locate the other one. I downloaded the manual which gives you a pic but the pic is so small that I can't identify anything around it to work out where to look. I'm sure thousands of you will know. I actually suspect that it may be on a garage floor about 250 mls north of here!!!
1 - 4 of 4 Posts
