Very cool! But I think I will stick to oiling the old fashion way...
Yup, I still have plenty......................Do you still have these or no?
Yes. Zip ties are used as oil guides and they rest against the sprocket... At least that's how I set mine up, and I hope I did it right!Im confused. Are the oil guides supposed to touch the sprocket?
Yep. It drips down the sprocket and centripetal force spreads it onto the chain as you ride.:/ Do they just drip down the sprocket? I don't wanna put them up against the teeth. If you could get a picture that would be awesome.
With the reservoir being mounted where it is, do you have to remove it completely to refill?Yep. It drips down the sprocket and centripetal force spreads it onto the chain as you ride.
It was tough getting a good closeup... especially using the sh!tty iPhone camera, but here's the best one I got:
No. I just attached some tubing to my gear oil container to snake in for filling. Otherwise, yes, I would have to remove it.With the reservoir being mounted where it is, do you have to remove it completely to refill?
LOL!...I also modified my Loobman oiler by removing it from my bike and tossing it.Well, my next 'mod' will be to remove this Loobman oiler and install it in the bottom of my garbage can. The oil reservoir leaks. There is a nice puddle of oil on top of my chain guard, and that splashes onto my tire. Not only does oil leak out, water leaks in. I now have about a 50/50 mix of oil and water in the reservoir. Since water sinks to the bottom, I can only 'lube' my chain with water. Lastly, the push button is terrible. I have to push and hold it, then push down a few more times for any oil to enter the tubing (when there isn't water in the reservoir, of course). It's getting worse the longer I have it on (less than a month now). I likely just got a lemon... But regardless, I'll be going back to regular chain maintenance until I spend the money for a Scottoiler.
Just got that from the maker!First I would again like to say thank you for the feedback you offered regarding the Loobman AB chainoiler and I was especially grateful for your pointing out the serious flaw, that the unit is prone to leaking and allowing rainwater into the reservoir.
Most internet reviews are meaningless (see the “Ride” article for example) so I don’t read many of them and, having had my own Loobman tucked inside the nose fairing of my Fazer, I had not been aware of the leak. All the same it’s a little strange that so many people are so busy telling the world about it that they couldn’t find the time to tell me! Thanks again.
The mould has gone back to the toolmaker for changes to make the next batch waterproof and I have just placed an order for waterproof caps to fit all existing Loobman AB chainoilers. The caps should be here in about a week.
As a small independent company it would be impossible to “recall” all the sold units but with the new cap fitted, the unit will work quite normally and it will be impossible for water to enter the reservoir.
If you could please supply me with your address I will send you one of these caps, complete with fitting instructions, as soon as they arrive.
As a gesture of thanks for your feedback and your patience, there will be no charge for this, however I would be very grateful for any further feedback you may wish to offer.
Whoops. I meant to reply back to you and in this thread, but forgot. I just received the same email from him, and an email a week ago, after contacting him about it. Thanks for the suggestion to contact him.Just got that from the maker!
