I installed a new handlebar today now the bike won't start. So I checked everything and it is the clutch that is the problem. (I took the grip off and tried and it will start.)
Now this is what I don't understand.
With clutch pulled in and in neutral it will roll.
With the clutch let out and in neutral it will roll.
With it in gear the bike won't roll with or without the clutch pulled in.
So I did some searching here and found the "clutch mantra". So I go about it that way and to the best that I could understand adjust everything as mentioned in the mantra. No dice, the bike still won't roll with the clutch pulled in and in gear. (Maybe I'm adjusting it wrong)
"Clutch Mantra"
http://forum.svrider.com/showthread.php?t=54588
I've been playing with the cables for a few hours and can't really get it back to how it was before the change.
Oil was just changed about 100 miles prior to this. So no problems with that.
From what I understand I loosen the nut then take a screwdriver and go counterclockwise till it is loose, then I go clockwise until I feel it tighten up and proceed 1/4 turn more then tighten the nut back up and adjust the slack in the cables.
It feels like there isn't a lot of slack after I tighten the nut back up. The clutch lever feels pretty tight right after.
Is this little lip supposed to go all the way to the edge or is there supposed to be space in-between with the clutch pulled in?
Thanks in advance, ~Blinker
"Clutch Mantra"
