1 - 1 of 1 Posts
picked these up from a coworker along with a power commander and k&n filter, all of it for $100 but i still owe him $30.
had to do a bit of a different mounting for them. the original plastic brackets that slide into the cut in the fairing were still used but i ground down the plastic stem so the bolt on the new ones would go all the way through and then the rubber end would sit flush against it.
they look great i think! unfortunately, the clutch side one isn't working. the rear clutch side works. the wire was extremely short on that side and i used a different styled connector for it. i thought i had a good bit on the wires but apparently not. used a lot of die-electic grease and nothing. i guess i'll just have to check continuity and see where it's losing the power at. any other ideas?
1 - 1 of 1 Posts
