1 - 19 of 19 Posts
I got the high mount pipe and as the rest of you could not figure a way to do my signals. I bought those little LED flush mount ones that go on the side of the body work. They could not be seen at all. Then I tried the clear alternatives and again they were dim and I did not trust them. So I installed my stock tail lights back. Then I took my stock signals and cut them up and remounted them under the passenger foot pegs. I cut the rubber arms down by 2/3s and re did the wires. I ran the wires up and under the foot pegs and glued them there with silicone. The signals are held on by a bolt and still have the stock clips inside the bike. The are highly visible from both sides of the bike and people have commented on them.
Comments welcome please!!
I love the concept. I may look into that further in the future.
I would suggest going to the smaller aftermarket housings though.
:D
There was a guy on the portal that actually drilled holes in the backside if rear peg support, and insrted LED's right in there and hid the wiring...came out really tight.
I have some RED leds'...I may have to experiment today...weather sucks ass anyway.
SV1k left pass peg, and make some spacers for the left peg w/longer bolts.
For a slightly more balanced look, and identical mountings. Just a thought, your idea is pretty good though.
intresting placement! thats kinda cool
i think it looks pretty sweet
is there a way to make the two vertical brake lights blink independently so it can function as the turn signal?
I think it would be sweet to have one blink independently of the other, then u don't even need turn signals on the back :!:
Oh and one other thing, go take care of that chain. ;) :p
I have a new chain and tires at the shop. I am installing them on Tuesday.
Doug
Avidrider installed some custom LED turn signals. I dont have access to a milling machine to make something like that. Plus I want visible. I did not want those aftermarket cat eye signals. I want to be SEEN! I had one close call with the old signals and all I heard was the screech of tires as I turned right. I went back a little while later and saw about 25 foot skid marks from the car.
I thought about the left right LEDs in the tail light, again I want visible. Am I stopping or turning? I did not want to have to worry about people thinking what I was doing.
Prez
What do you mean a sv1k? Do they have some different passenger pegs that would mount up? I know my signals are a little off. One is about an inch farther back and a little lower.
Well, the SV1k has dual cans. So, the left pass rearset would have a hanger, just as the right side. Mounting points should work, both SV's have the same body work and subframes should be nearly identical.
avid did it too. i remember seeing pics - looked tight.
nice job with the stocks xyster
xyster101 said:
Doug
I think the guy that did it from the portal had an undertail with lights in it, as well the one milled into the rearsets. I do not if Avidrider is the same guy tha I am thinking about.
Nope, but I can tell you that LED's inset into a footpeg like that will certainly not be visible during the day time.
Neither are my Hotbodies undertail ones...LOL.
You got a pick of what you did????
This a pic from the one that I am talking about:
Oh, very nice set up Avid. I never saw that before now, thus why I asked for the pics. Good job.
Discussion Starter · #19 ·
Adam,
Do you have pictures of it outside with the sun to see how bright it is? Just curious since you have the super bright LEDs in there.
1 - 19 of 19 Posts
