I've got the GenMar also, but the 1" up by 1 3/8" back. The end result is that the bars are mainly pulled back, due to the angle of the top clamp. This will max out the brake line, and you will have to cut the tie clips that are around the electrical bundle and handlebars. In a perfect world, I wish that there was more slack in the cables, wiring and brake line..then I would get different bars. The way it is now, I doubt if I can raise the tank unless I either remove the risers (which I don't want to do) or remove the fuel tank hinge bolt. I don't want to remove the risers because I don't like the idea of putting stress on the bolts. Also, you will need two more chrome caps, and for some reason my caps did not fit correcty in the new bolts. I added some A/C stainless tape around the cap plugs in order to make them fit tight going into the new bolts. Another reason why I don't want to mess with them.
