actually the 14 will have more torque and less top end in comparison to yours. lowering the amount of teeth on the front sprocket or increasing teeth in the rear sprockets increase torque. also each tooth in the front is approximately the same as three in the back (talking about performance changes).I have the same project coming up this week, 105 ft lbs, good to know. I'll do it by feel then check my work with torque wrench . I went 15/46 just a bit lower what does a 14 do for you, top speed in 6th gear? i believe sv's go faster in 5th than sixth.
a 14 in the front would be close to a 47-48 on the rear. the bike is a lot snappier. sure makes popping a power wheelie a lot easier.I have the same project coming up this week, 105 ft lbs, good to know. I'll do it by feel then check my work with torque wrench . I went 15/46 just a bit lower what does a 14 do for you, top speed in 6th gear? i believe sv's go faster in 5th than sixth.
