Hi all,
I am in desperate need of a radiator fan for a 2nd Gen SV1000(S).
I have scoured ebay/craigslist etc. and have only found ones for an SV650. They are different part numbers so I am not sure if they will work or not.
Some people have mentioned finding some randomn ones as long as they are 12 volt but would those work with the SV plugs (power and switch)?
Thanks!
Does the cbr600rr entire assembly bolt straight up to a 2005 SV1000s rad or do you need to bolt the cbr fan into the SV metal cage/housing? My fan assembly is so twisted it'll be a pita trying to straighten it. Also does it have the same switch lead connector as the SV? Cheers
After buying the fan blade for the cbr600rr I can say it is definitely the correct unit, however I'd love to know the answer to your question as well because my brackets are bent and I was thinking about trying to buy an entire cbr motor with the bracket but I don't know that it is the same so if anyone can clear it up for sure..
